Please help,
I'm not sure which orientation the back-plate should be at (Thermalright Silver Arrow). A or B
Unfortunately as you can see I'll have to remove the mobo to install the backplate .
So i'd like to get it correct the first time :thumb: Mobo is an asrock extreme 3 gen 3.
Thanks for advice. Both ways use the correct holes marked as 1155 on the mobo.
