Silver Stone DA650 | Teardown | inspection | Cleaning |Fully Modular PSU
beret21
Old is gold
So still using the same PC for years. A big MOD is coming i will be watercooling the system and ocing the GPU. So needed a bit more power to be on the safe side. Its a 650W PSU with single rail. Like every used part i buy. I first test it then tear it down for cleaning n fun n inspection. It had a little dent and the modular PCB was also bent that i tried fixing. This was one satisfying teardown
SPECIAL FEATURES
Class-leading single +12V rail with 54A @ 50℃
100% modular cables
Single PCI-E 8pin connectors & dual PCI-E 6pin connectors
Quiet running 120mm fan
Supports for ATX 12V 2.2 & EPS 12V
Active PFC
Efficiency greater than 80%
Japanese primary capacitor
[video=youtube;rLuadGnYpsw]
