video card & psu
paulwc35
will this psu work Antec CP-850 850W Continuous Power CPX SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC "compatible with ...
CP-850 Spec
Type CPX
Maximum Power 850W Continuous Power
Fans 1, PWM (Pulse Width Modulation)
PFC Active
Main Connector 20+4Pin
+12V Rails 4
PCI-Express Connector 2 x 6-Pin, 2 x 6+2-Pin
SATA Power Connector 9
SLI Certified
CrossFire Ready
Modular Yes
Energy-Efficient 80 PLUS Certified
Input Voltage 100 - 240 V
Input Frequency Range 47 - 63 Hz
Output +3.3V@24A, +5V@30A, +12V1@22A, +12V2@22A, +12V3@25A, +12V4@25A, [email protected], [email protected]
MTBF >100,000 Hours
Approvals UL, FCC, TUV, CE, C-tick, CCC, CB, BSMI Features
Connectors 1 x Main connector (20+4Pin)
1 x 12V(P4)
1 x 12V(8Pin)
9 x Peripheral
9 x SATA
1 x Floppy
4 x PCI-E
Features Please note:
This unique power supplier exclusively compatible with some of Antec's most cutting-edge Gamer and Performance One enclosures, including the Twelve Hundred, P183 and P193
Compatible with Core i7
Advanced hybrid cable management to improve airflow and reduce clutter
Unique power supply construction compatible with many new Antec cases
Dual PCB layout optimizes cooling efficiency and allows for heavy duty components
Quiet 120mm PWM cooling fan
Safety protection circuitry prevents damage resulting from short circuits, over current and over voltage
Chipset Manufacturer NVIDIA
GPU GeForce GTX 580 (Fermi)
System Requirements Minimum of a 600 Watt power supply. (Minimum recommended power supply with +12 Volt current rating of 42 Amps.)
:bang head please help me
Yeah, that PSU will work with a GTX580.
What does the rest of your system look like?
Update20-231-415 G.SKILL Sniper Gaming Series FM-25S2S-120GBSR 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
Model #:FM-25S2S-120GBSR
Item #:N82E16820231415
Return Policy:Limited Replacement Only Return Policy
In Stock
Note (Add20-231-415)
Save Cancel $239.99 -$10.00 Instant $229.99
Update17-371-024 Antec CP-850 850W Continuous Power CPX SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC "compatible with ...
Model #:CP-850
Item #:N82E16817371024
Return Policy:Standard Return Policy
In Stock
Mail in Rebate17-371-024
Note (Add17-371-024)
Save Cancel $139.99 -$20.00 Instant $119.99
Update14-130-587 EVGA 015-P3-1580-AR GeForce GTX 580 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Model #:015-P3-1580-AR
Item #:N82E16814130587
Return Policy:VGA Replacement Only Return Policy
In Stock
Mail in Rebate Card14-130-587
Note (Add14-130-587)
Save Cancel $479.99 $479.99
Update11-129-100 Antec Twelve Hundred V3 Black Steel ATX Full Tower Unbeatable Gaming Case
Model #:Twelve Hundred V3
Item #:N82E16811129100
In Stock
Mail in Rebate11-129-100
Note (Add11-129-100)
Save Cancel $167.99 -$8.00 Instant $159.99
Update13-131-730 ASUS P8Z68-V PRO LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Model #:p8Z68-V PRO
Item #:N82E16813131730
In Stock
Note (Add13-131-730)
Save Cancel $209.99 -$10.00 Instant $199.99
Update19-115-072 Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
Model #:BX80623I52500K
Item #:N82E16819115072
Return Policy:CPU Replacement Only Return Policy
In Stock
Note (Add19-115-072)
Save Cancel $219.99 $219.99
Update20-145-347 CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9B
Model #:CMZ16GX3M4A1600C9B
Item #:N82E16820145347
Return Policy:Memory Standard Return Policy
In Stock
Note (Add20-145-347)
Save Cancel $119.99 -$20.00 Instant $99.99
Update22-148-506 Seagate Barracuda XT ST32000641AS 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:ST32000641AS
Item #:N82E16822148506
In Stock
Note (Add22-148-506)
Save Cancel $159.99 $159.99
Update24-009-222 Acer GD235HZbid Black/orange 23.6" 2ms Widescreen 1080p 120Hz 3D LCD Monitor
Model #:ET.UG5HP.001
Item #:N82E16824009222
Return Policy:Monitor Standard Return Policy
In Stock
Note (Add24-009-222)
Save Cancel $399.99 -$72.00 Instant $327.99
Update26-104-281 Logitech G35 USB 2.0 Connector Surround Sound Headset
Model #:981-000116
Item #:N82E16826104281
In Stock
Note (Add26-104-281)
Save Cancel $129.99 -$40.00 Instant $89.99
Update27-135-204 ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Model #:DRW-24B1ST/BLK/B/AS
Item #:N82E16827135204
In Stock
Note (Add27-135-204)
Save Cancel $20.99 $20.99
Update35-100-007 Arctic Silver 5 Thermal Compound - OEM
Model #:AS5-3.5G
Item #:N82E16835100007
Return Policy:Consumable Item Refund Only Return Policy
In Stock
Note (Add35-100-007)
Save Cancel $12.98 $12.98
Update35-209-054 Antec KUHLER H2O 920 Liquid Cooling System
Model #:KUHLER H2O 920
Item #:N82E16835209054
In Stock
Note (Add35-209-054)
Save Cancel $119.99 -$5.00 Instant $114.99
Subtotal: $2,236.86
Select All - Select None
Add To Cart Delete
No need for 16GB of ram for 95% of people. Get 8GB unless you run multiple VM's, do HEAVY HD encoding/rendering.
ok this is my my set up 1 x ($189.99) MB MSI|990FXA-GD80 990FX AM3+ R $189.99
1 x ($199.99) MNTR ASUS|LED 24" 2MS VS248H-P R $199.99
1 x ($111.99) CPU COOLING ANTEC| KUHLER H2O 920 R $111.99
1 x ($3.99) EXT ENCL IOCELL NW|TRAVELER 251U BK $3.99
1 x ($89.99) HD 1T|WD 7K 64M SATAIII WD1002FAEX - OEM $89.99
1 x ($159.99) CASE ANTEC|TWELVE HUNDRED V3 RT $159.99
1 x ($189.99) CPU AMD|PH II X6 1100T 3.3G AM3 RT $189.99
2 x ($359.99) VGA SAPPHIRE|100311-2SR HD6970 2G R $719.98
1 x ($129.99) PSU ANTEC|CP-850 850W RT $129.99
1 x ($69.99) MEM 4Gx2|GSKILL F3-14900CL9D-8GBSR $69.99
1 x ($98.99) HEADSET LOGITECH | G35 R $98.99
1 x ($12.98) CPU THERMPASTE|AS5-3.5G % - OEM $12.98
Payment Summary:
Total Amount: $2016.78
