I got my bayres filled to allmost the max now. At least it doesn't swallow air into the tubes anymore
I finished the case for allmost 100% las night. Working till half past one and getting to work the next day is kinda hard
Anyways, here are the pictures!
Shows the tube I made on the bayres. It wasn't fully leak free, but it did the job. Allmost all air is gone now.
This shows the machine with everything installed and a lot, I repeat, a lot of tie-rips! I need to get something to plug the HDD coolers to the thermal sensor bay, that's why not all the cables are nicely worked away atm.
All in all it took way more time then expected (allmost four weeks instead of just one) but it was all worth it.
The only things I need to take care of now are the fan header for the HDD coolers, getting two 80mm fans for in the side bracket and I need to dremel the Tweakmonster BGA heatsinks to fit between the capacitors and on the mosfets.
Tonight I will make some more pictures from different angles. Front, back, other side.
