- Oct 14, 2007
Martin thinks (and it stands to reason) it has to do with the 90° bend on the inlet. Most (all?) aftermarket tops have inlets up top that eliminate the bend.
but that one small diameter puts alot of resistance on the whole loop -
Some things to consider:
1. NPT Pipe thread size is not related to pipe ID diameter.
...A 1/4" NPT pipe thread uses nearly a 3/4" drill drill bit. This is ID .vs. OD
2. If you double the diameter of a pipe you increase its volume by 4X.
The water block(s) have a lot more resistance to flow than any other
component in the system.
When you have a restriction : at the point of restriction(Vena Contracta)
you have a pressure loss(pressure drop) at some point after the restriction
point you have a pressure recovery but it is never 100% and you have a
flow loss that does not recover.
it still stands. you have used a lot of adjectives that don't fit
in one of your other posts you use the word tremendously.
what im getting at is the original poster is looking for some information. If what you just said in quotes was true then there would be almost no flow due to the cumulative properties of resistance .
and im saying this is misleading and in some situations completely in correct.So as an example closer to the world of liquid cooling - if you have a water block that provides x resistance at 100gph it matters not that your tubes are oversized and provide 25% of that resistance - almost all of the resistance is going to be caused by the component with the most resistance.
this is all true except that the NPT size IS usually related to pipe ID, atleast when it comes to schd 40 pipes, and most others - a 1" npt thread is going to have an inside diameter of a 1" schd 40 pipe - which is around 1"
The 'G' is a BSPP spec, British Standard Pipe Parallel (parallel threads instead of tapered), and can be found under ISO 228 ...
What we are arguing about is the fact that you think resistance accumulates, whereas I am saying that resistance is mostly caused by the single thing in the system that resists the most(provided its a closed loop with all components inline).
BTW, I am the original poster and I wasnt clear on why people were using 1/2ID tubes with 1/4g thread (I was assuming that ID of it is 1/4 as it would be with regular plumbing fittings e.i. plastic copper or pex pipes)
http://www.engineeringtoolbox.com/british-pipe-threads-d_754.htmland British Taper threads, BSPT (British Standard Pipe Taper Thread)
The 1/4" BSPT is remarkably close to 1/4" NPT too.
Sorry, I didn't see a 'G' standard under tapered thread and (I guess incorrectly) assumed it was strictly a BSPP standard. Maybe these guys need to update their webpage.Parallel (straight) Threads
BS parallel threads are also referred to as British Gas, British Pipe Parallel or Parallel Fastening Thread.
Common symbols used for the thread: BSP, BSPP, BSSPI, BSPF, BSPG, PS, Rp, G
The BSPP (parallel) male will mate with a BSPP (parallel) female or a female port.
Usually marked: G size ISO
Taper Threads
BS taper threads are also referred to as British Standard Taper Pipe, Pipe Taper or Conical Thread.
Common symbols used for the thread: BSPT, BSPTr, PT, KR, R, Rc
Usually marked: Rc size ISO
Characteristics of BSPT taper threads:
