- Sep 13, 2003
- Lubbock Tx
would 4 foot of sleeving be enough to do a standard PS? Im ordering all the sleeving and shrink this weekend. Also getting the molex removal tool from radio shack today
Fushyuguru said:I am actually going to do a PSU sleaving tutorial within the next week or so. Waitin on some sleaving to come in.
I buy in bulk, but 10-12 feet should do you. 1-2 of 1/2" for the ATX 20pin, the rest 1/4" or 3/8". 1/4" should be best for molex's. Then get 1ft of 1" shrink and 2-3ft of 1/2" shrink.
Best places for shrink and sleaving is www.performance-pcs.com or www.svc.com .
Molex's you need to use a small jewelers screwdriver to remove the pins, or a molex extractor. The ATX plug and 12v plug, you need a mini-fit molex extractor. Though they cost ab $20. If you can figure out a way, then use two really really small screwdrivers to reach inside that plug and get those pins out. Rem to label them or you could end up kicking yourself.
Or you could bypass that whole mess and just get a PSU with atx 20pin sleaved (though I have the tools ).
Ok thats all for now, untill the tutorial.
