- Jul 26, 2004
- Somewhere in Washington State
sticky this it needs it badly
JudgeDredd said:I agree, this should be stickied. However, you should also go a little bit deeper and bring up such topics as required power, required cooling, and SLI overclocking... or at least make another thread with those advanced topics.
Hoot said:I'm proud to sticky such a worthwhile thread. Good work LoneWolf...
Hoot
You need 2 IDENTICAL (same model and brand)
Anandtech.com said:Two graphics cards with identical GPUs from the same manufacturer. Video BIOS revisions must also be identical.
nvidia.com said:Can I mix and match graphics cards?
No. NVIDIA currently doesn't support SLI on two different models or from different vendors. SLI supports configurations with the same model (i.e. 6800 Ultra) from the same vendor (Vendor XYZ). A common misconception about SLI is that the BIOS revision has to be identical between the cards. This is not true. A manufacturer can revise the BIOS without affecting SLI.
