I am trying to decide between two radiators for my first custom build and need advice. I will go with either the Hardware Labs Black Ice Nemesis 420GTS (30mm) in Push/Pull or the Nemesis 420GTX (55mm) in Pull only. I plan on running 140mm fans at 800-1200 rpm. What I've gathered is that the Push/Pull setup on a thinner radiator should have better performance at lower rpms and the thicker radiator in Pull should perform better at higher rpms. At what point (fan speed) would the larger radiator in pull be more beneficial than the thinner radiator in push/pull if at all?
