pctuner@amd
DO NOT TRADE WITH ME AS I HAVE SOLD OTHERS DEAD OR
- Nov 14, 2002
- Tampa Fl.
it is true the mobo does only need to be removed for initial install thats what the levers on the side are for they are to catch the mounting plate whaich is first mounted to the mobo and they lock the hsf down on the mobo I personally went with the MCX462+T because I wanted supercooling and I got it I run at 13c 1.9v load now that I got the proper power supply and this thing is so simple to put on and off you don't have to worry about the stress on the socket lugs either because there only made to really hold a stock size heatsink thats why the slk800 uses all three. I think its way to much for the socket and has to apply somewhat uneven pressure on the cpu die not to mention the socket.
