- Jul 9, 2001
- Louisville, KY
had a similar problem for slot 1 to PPGA had to use a gigabyte b/c it was smallest
Snarkey said:Slim_lim, had the same temp probe problem with the asus 370dl. Running a cel566@950. MBM always read the same. I found help on the Overclockers site. I have a p2b-f with the cpu temp pinout. Radio Shack has a diode for $1.80 that I laid under the retention clip right over the core. I know, it was hairy! I ran the leads over to the pinout and the bios picked it up right away. I know that I have to assume some things. I used a infrared shooter to read the point of contact and compared that to the bios. Recorded it. Then ran every monitor software that would pick that sensor up. Recorded that. Then put it all together and took an educated(?????) guess. I came up with an 8 degree compensation. It's the best I can do. And I feel safe with it. They say that the slocket should pick it up but this is what I had to do. Good luck and good holidays.
