- Apr 1, 2010
Hi, I'm running Speedfan on my HPa1250n PC and for a long time now(over a year), the heat sensor on the SMSC H/M block, referred to as 'remote 2', is registering at about 121 degrees C, while the temp on remote 1 is only 35 degrees C. The high temp fluctuates a bit which leads me to believe it's not a disconnected probe. The ambient temp fluctuates as I speed up or slow down fans, but it is generally under 40 degrees C. I'm thinking the high temp on 'remote2' is affecting my graphics card,as I'm currently running a GeForce 8600GT and it is idling at 55 degrees C and climbs rapidly to 80 degrees under a load. When the 8600 was in another PC, it didn't idle at that high of a temp. Anybody have any ideas on what may be happening I have plenty of case fans blowing, sounds like a windtunnel. Thanks
