d94 said:now running in windows @ 267x14=4ghz @ 1.375v
d94 said:just finished running 3dmark @ 4ghz.. NP!
only thing is load is 65C
Why are you using 15X? Might as well get the bandwith you need with 14Xd94 said:just finished running 3dmark @ 4ghz.. NP!
ZL1 said:WOW ! Congrats
by the way how does it feel/bench compared to a 6-series ?
D
P.S. be careful with those temps
im using bios 509Category 5 said:What bios are you using? I have the same board and CPU and for some reason can't get stable at above 3.75. I am leaving all voltages at AUTO except Ram (2.0v) and CPU (tried up to 1.45 but couldn't even do 3.8 stable with that).
I am wondering if it's my bios (0422) since I was able to boot at 3.99 with 1.45v and temps were 39C idle, and at 3.75 idle temp is 37C. I didn;t get to see lead temps since it rebooted, but I imagine it isn't too high. Bios reports 45C (42.5C at 3.75). 3.75 (250fsb) is rock stable, with ram at 833 (DDR2 800 OCZ Gold). PS is a powerstream 520 so I doubt it's the problem.
I really expected at least 3.85 since I'm on water...but hoped more for 4.0GHz full time at no more than 1.45-1.5v.
What do the gurus think?
Shane
hehe i may just do thatdylskee said:Nice work d94! If you have a high cfm cpu fan try flipping it over and pulling the air off your cpu, i did that with my 3.0E and my temps dropped 4~5c.
fsb term volt?HempHog said:I'm guessing you need to change your FSB termination voltage also, usually when scores get messed up like that it's because everything is out of sync, and its gets more and more out of sync till it crashes.
