- Aug 16, 2009
OK I got off my *** last night updated my chipset drivers and installed my new card Sapphire RX 6900 XT. Right off the bat on reboot it will hang on bios load, (A5 or D9 I think vertical GPU mount was in the way) but if you leave it sit long enough it will work itself through, most of the time. That's on Asrock BIOS 3.80, downloaded the latest BATA Bios 3.91 same issue, rolled back 1 version of my shipset driver same issue. Reset Bios to default proffered settings and there's no issues but as soon as I make any changes in BIOS, like just setting my ram to 3600 14 14 14 14 32 or just enabling S.A.M will put me right back to square 1. I stayed up too late last night considering I had to be up at 4 for work I know I will regret that but this has me scratching my head. A5 was the last code I seen but will disappear and the system will just sit there. This am I reset BIOS to default, boot right up, I am typing this on it. I downloaded and ran Supposition for the Overclocktagon 11100 ish can't remember exactly. Any thoughts???? I'm baffled. I'm off to work and will check back in as I can later, today will be a busy day.
