- Oct 29, 2005
- Oregon
I think I royally screwed up, not sure. Pc turns on, lights, etc., but monitor nor keyboard react whatsoever.
I had the CM aoi water cooler in sig installed using one only fan it came with to pull. My board has no more pinouts at all, cept for the std 5V hd cable ends and the second fan has a 4pin plug (for the board), and I had no adapter so I left it off.
Stupidly I decided to attach the second fan for a proper push pull rad config (front intake mounted). I tried saving the cm fan 4pin connector and simply sticking bair wires in (from a hd power adapter), then wrapping it all in elec tape. When I first turned it on connected, I think it shorted something as nothing happened at all. I removed it, hit the power button, and now neither the monitor nor the keyboard are recognized though initially both fans and the pump were working.
Will a cmos reset work??? Or am I looking at buying a new board?? Any knowledgable help much appreciated. Damn I feel really stupid.
UPDATE
3-4 months later turns out I blew the cpu and possibly wrecked a 2tb hd controller (all my videos-nbd). Bought a new ps-nope. Bought a new mobo and handed everything over to a pc guru who narrowed it down, finally, to the cpu. Over $600 later lesson learned. On a good note the pc guy organized all my wiring so at least the insides look great-lol. I bought an NZXT Grid+ V2 6 port fan controller. Software SUCKS!! but with a little tweaking does the job.
UPDATE
