- Oct 29, 2005
- Oregon
Have a new build (sig). Install gets to the part where it says please load device driver and I don't have the proper inf file. Had this problem before in a previous install using a sata drive and used a silicone image driver which worked fine. This ones a samsung 120gb 840 evo connected to an asrock amd bolton mobo. In asrocks website they do not specify device drivers for the optional msata install. Normally it's the wireless ac/bt4 module. Samsung is lame as f because they want you to have a special optional msata to usb cable, using their 'migration/clone' software and do it all within a single session. I was considering installing to a std sata drive (I have a spare 320gb which just happens to be my previous os disk) and then 'cloning' with acronis (PITA). All I need is the correct inf file for the install but have searched and searched and can't seem to locate a proper down link for what file I don't even know; si, amd, asrock, samsung ???
Has anybody encountered this problem and if so where is the file dammit? Any help appreciated. BTW the bios on this board is amazing and I'm getting access to a cat5 cable this eve so I can actually internet it through the bios which may help, even though all I need is the dern file.
