I got some Questions about the Temperatures of my CPU.
Mainboard : ASRock 870 Extreme 3
CPU : AMD Athon II X3 445
cannot find info about my CPU cooler but it is one with a Headpipe and was recommendet about 2 years ago as on of the best.
Iam using AIDA 64 to read the Temperatures because i think that these are realistic ones.
I tried CoreTemp, SpeedFan, and the OC tuner software but every programm even if all 4 run at the same time shows different Temperatures from 39 ~ 88 degree.
If UCC is off the system runs Stable at
CPU 45
Core 1 39
Core 2 39
Core 3 39
If i Activate UCC the system runs at
CPU 60
Core 1 70
Core 2 70
Core 3 70
Core 4 70
CPU-Z shows that the CPU now runs like an Phentom X4 B45 with 4 Cores but without the L3-Cache.
I stress testet the CPU while using Prime 95.
so my primary questions now are
1. which Temperature is the importent one, the CoreTemps ore the CPU temp ?
2. I cannot realy find any informations about the max temp of this specific CPU do anybody of you know it ?
CPU 45
Core 1 39
Core 2 39
Core 3 39
CPU 60
Core 1 70
Core 2 70
Core 3 70
Core 4 70
