Hi guys/girls, I am fairly new into the forum, and hopefully getting some really basic answers here, lets start with my specs, I currently have
2700k with silver arrow
p8p67 rev 3.0
gtx 580 amp! with artic cooling accelero extreme II
8 gb of corsair vengenace ram
ax 750
and 600T with side window panel
The comp runs fairly quiet already, but I am really looking into some upgrade for some water cooling action to prepare some quietness for my school in sept. So my potential upg list is as follow
600T ----> NZXT swith 810 matte black case
p8p67 -----> Asus maximus v formula (not yet release, with built in water cooling compatibility, main reason for going wc for the full loop)
gtx 580 -----> debating whether I should go gtx 680 or 670... 680 are running low in the water blocks from ek, and 670 is still in precess of making the blocks
water cooling parts:
res: Swiftech MCRES-MICRO REV2 Clear HI-FLOW Water Cooling Reservoir
pump: Swiftech MCP655
Tubing and fitting will be depending on the built in size of the mother when it comes out, and compression fittings will be chosen.
cpu block : EK-Supreme LTX or xspc Raystorm, or Bitspower Summit Ef Cpu Liquid cooling block.
and now my questions for the Rad is that I will be doing triple 120mm up top in the switch 810, if I choose a think triple 120 rad like RX 360 it would not fit a push pull, so would it be better performance if I go with RX 360 ( think rad) with only push OR pull, or should I go with a normal triple 120 rad like swiftech MCR 320 with push and pull? fan wise I am thinking of cooler master R4 red led.
And would it be a lot more beneficial if I add another 240 rad ? but with four extra fans I would assume that defeats my purpose of silence though.
**And last questions would be if i go with 360 rad, and i put six 120mm fan for push/pull plus one additional case fan 120 mm, thats seven 120 mm fans in total, so how is that going to propose a silent pc operation? or do I just add resistors on all the fans to make them run at 5v while maintaining a fair temp?**
So basically this is my project for the summer, lots of ordering and most research are done, just need a bit of suggestions and advise before I actually get started!, thanks a lot for any help
p8p67 rev 3.0
ax 750
