My core temps drop to 0 at fairly regular intervals, see pic. you can see the warning flashing on the CPU bars and the dips on the line drawing underneath.
Anyone else seen this on there system? it does not seem to be replicating it in HWMonitor.
do you have clean and quiet or or their boost options enabled? when it puts the core into idle state it shows a temp of 0c. Its not uncommon to see this value on some of the different core temperature monitors.
having the epu software enabled will do it aswell.
I know theres some cores out there that naturally do that aswell, llanos have a tendency to do it despite having it forced off. I checked the one of the api's aswell for temp monitoring and when a core goes into a parked state by the os it seems it can also show that temperature state.
mabye we should increase frakks core voltage some to take care of this instability
