A DMM is a digital multimeter. It's a device that measures voltage, resistance, and amperage.
Right now, I don't remember the specs of the voltages, but, you can't trust the readings that your Super IO chip gives you. They're usually wrong. If you're concerned on your voltages and PSU accuracy, you should take a DMM out and check the voltages yourself.
