Finding good data on the JMicron JMF602 controller is nearly impossible, but from what I've heard it's got 16KB of on-chip memory for read/write requests. By comparison, Intel's controller has a 256KB SRAM on-die. And I'm going to go out on a limb and assume that given Intel's experience with CPU caches, that its SRAM implementation is probably very well done.
With the JMicron based solutions, if you try and write too much to the drive (and trust me, it won’t take a lot) and the buffers get full, the controller tells the system that it’s not ready to write more data and you get a pause.
When you cause the JM602’s internal buffer to overflow, your system runs in bullet-time. Applications take much longer to launch and close, windows take longer to appear, and there are distinct pauses in anything you want to do that involves the disk. Want to send an IM? Well, that writes to an IM log - you can expect a pause before you can send your IM. Loading webpages is the worst, reading from and writing to the cache wreaks havoc on these cacheless MLC drives. Just for kicks I tried loading AnandTech while I was extracting a 5GB file on the SuperTalent 60GB MLC, it took over 10 seconds for the website to load. Once the JM602 was free to fulfill the read request, the website just popped up - but until then it was like my DNS was failing. It’s a lot like what happens to your notebook if you try and do too much, the disk quickly becomes a bottleneck.
Tweaks aren't a guaranteed fix for the controller's faults. With the Core V1 and V2, I've gone through the OCZ tweaks with a fine toothed comb and made sure I applied them all correctly, as have others with the JMicron drives, only to find that the stuttering persisted. Users like you who have zero issues are few and far in between.
Features:
Fully compatible with devices and O/S that support the SATA I standard
Built-in ECC (Error Correction Code)
Wear-leveling algorithm ensures reliable data transfer
RoHS Compliant
Low Power Consumption
Certification: CE, FCC, BSMI
2 Year Warranty
*For OS installations, SLC version is recommended!
Specification:
Size: 100mm x 69.85mm x 9.5mm
Op. Voltage: DC 5V
Op. Temperature: 0°C(32°F) to 70°C(158°F)
Weight: 48g
MTBF: 1M hours
[SLC] Max Read 136MB/s, Max Write 96MB/s. (8GB)
Max Read 135MB/s, Max Write 105MB/s. (16-32GB)
Max Read 163MB/s, Max Write 142MB/s. (64GB)
[MLC] Max Read 123MB/s, Max Write 60MB/s. (32GB)
Max Read 148MB/s, Max Write 92MB/s (64GB)
Max Read 163MB/s, Max Write 92MB/s (128-192GB)
Shock: 1500G, 0.8ms
Vibration: 3.0G, 5-800Hz
You did alignment as well and still experienced the stuttering? I gathered from reading ocz forums that proper alignment was the best tweak to alleviate stuttering. I was thinking about the lower end series but now I don't know. Probably best for me to continue waiting out Vertex with corrected firmware.
Nevermind, that looks to be for xp only.
Yes, alignment was done on both XP and Vista installs along with the tweaks mentioned in the stickies. The only thing that got rid of stuttering for me was SteadyState.
The drives were tried in a number of machines btw, from a Gateway 7811FX to my 1000H to a E7200 P35 desktop.
stuttering issues can be fixed by using a raid card with onboard cache. another way to fix stuttering is to correctly align the partion for XP if your using it. as well as using MS-steady state. how ever this will increase bootup times since it takes random writes and turns them into sequential writes to the drive.
Vertex is a MLC based SSD that should be out soon, as said with no jmicron controller. however the Vertex drive will feature onboard cache on the drive to fix stuttering issues. i would personally at this point wait for vertex but it is a bit pricy.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10009849
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10009850
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10009989
spawn,
even if it doesnt have the jmicron controller it will still stutter unless it is packing some on board cache. for the price i would rather get this drive.
the ST OX drive for the price is way better then the corsair spawn listed. in raw read/writes the OX drive will beat it. not only that but the OX is half the price, there are some reviews for the ST OX drives. i forget which size was tested but i will have to try to find them...
hey guys, anyone can confirm that using a pci controller can totally eliminate the $tu?id stuttering?
also, to sum it up... #1 what SSD brand and model is/are guaranteed that doesnt have stuttering/freezing issue thats "currently" available in the market? #2 what are the benefits of the future (will be available soon) gen SSD's? #3 any brand and model in particular (from #2)
Thanks
Sil
