- Mar 12, 2002
If your like me you have alot of Matroska media, but as you have quickly learned most devices simply do not support this container. If you happen to use a PS3 or a number of Blu-Ray players for media streaming you are all to aware of the issues caused by the Matroska container. To compound this sometimes even when your player happens to support the mkv container you can still run into audio sync errors and a number of other things that make viewing feel like a job rather than recreation.
Now I have a solution for you! As most of the mkv videos out there typically contain an MPEG 2/4 coded video stream it is possible to Re-Multiplex them into an MP4 file container.
What are the advantages of Re-Muxing VS Re-Encoding???
Simple remuxing can be performed at the speed of your hard disk, there is no loss of quality, and it requires little to no CPU usage. As you can see there are many benefits to Re-Muxing VS using a program like handbrake to re-encode.
So whats the down side?
Not all content can be held inside of an MPEG-4 container. Matroska is known for its ability to hold darn near anything, but that is exactly why it has the support issues that it does. The MPEG-4 container has strict limits on what types of content can be within it so supporting it is easy.
Are there other easy to use Re-Multiplexers out there?
Yes but at the time of writing this there are currently NO OTHER options for remuxing in batches. Handbrake can indeed do batch conversion but it is still experimental AND it requires re-encoding of the files.
So whats the catch?
The content in the folder MUST contain exactly the same number and type of streams in the same order. A single file within the batch with a missing audio stream, or with streams in a different order will cause this program to fail. Other than that Im giving this away, please use it to your hearts content!
If there is a feature you would like to see added, or some other format you would like to see supported let me know Ill see what I can do for you!
I know some people may be concerned with downloading a program from a forum from an unknown developer, but I assure you this application does not contain any malicious software, and I will happily provide the source code for this application TO A MODERATOR with the necessary coding skills if requested.
For installation instructions, container limitations, and usage directions see the enclosed readme.
*Note this application currently only runs on windows with Java SE 1.6 or newer.
CURRENT RELEASE, 15-JUNE-2013 0.9.1 BETA
So whats the catch?
