Found a problem. CoreTemp and HWMonitor wont read my cpus temp. It's been like this since I got it so idk what it could be.
Sounds like you have you have CPU unlock / unleashing enabled in your mobo. Since you have no cores to unlock, this setting is completely unnecessary and interferes withyour temp readings.
Edit: For clarity, this is a BIOS setting. Its called "CPU Unlock" "UUC / UCC Core Unlock" "CPU Unleashing" "Core Unlock" or something along those lines in the BIOS. I'm not 100% sure, but enabling individual core control might also interfere with temp readings. With 6 core Thubans, these settings aren't needed
Thats exactly what it was! Thanks! Its idling at 13 degrees Celsius. But now I'm trying to make sure its a stable overclock. Its been on almost all night and most of today and I've been playing games like BF3 and GW2 and no problems so far.
Have you tried using a Prime95 blend test. At the end of the day if you are happy that you can game on it without crashing that's cool(I'm doing this right now). But that stress test causes my 1045T to heat up another 20 degrees Celsius over the max temp it hits in BF3 and can show you if you're using enough voltage. I'm jealous though, I've got a really bad 1045T I can't play BF3 at that frequency unless I feed it over 1.6 volts. Don't use voltage like that though, just adding this sentence for people who might think 1.6 and above is recommended, it's most certainly not.
You don't say whether the 34c max temp is the core temp or the CPU socket temp. That's why I asked you to attach the HWMonitor interface so we could look at both.
Why do you have your ram frequency clocked so low and your ram timings are much more relaxed than they need to be. The CPU-z memory tab shows that your ram is only running at 1120 mhz and it's rated for 1600 mhz.
