- Dec 27, 2008
Eh.. I can't get it to overclock anymore with it being stable. I think I'll leave it at 3.6Ghz for now until march when I get a FX 8350. I ran a 5 hour test with it and only core #2 failed out of all 6. So I guess I'm in good shape!
Having a core drop out usually means you need a tad more CPU vcore. Your vcore is pretty low still and so are your temps, at least as they were in the last pics you attached. Why don't you increase your vcore a tad and see if you can get higher. Don't worry about dangerously high voltages until you get well past 1.5 volts for vcore. Temps are a better barometer of safe voltages until then.
RGone is correct. Your motherboard will not stand up to an 8350, at least not if you will be overclocking it. Probably okay at stock speeds and voltages, though. The "power phase" components just aren't stout enough.
