flyinryzen
- Oct 9, 2017
Need advice, I would like to run cooler+quite system, overclocking would be a bonus. But can't decide if water cooling is my best choice.
Ryzen 1800X - in SegFault RMA shipping right now to Miami (Wraith Max cooler)
Zotac GTX 1080 GPU
ASRock Killer SLI X370 motherboard
http://www.microcenter.com/product/476928/Celestrium_GXH7200I_Desktop_Computer (actual system/case)
It looks like case is designed for radiator in top or front of case...
Pros:
Probably quieter
Only option to reduce GPU temps
Fun project
Might allow slight overclock - 1800X as I've read, doesn't really overclock
Cons:
I don't want to spend a lot, so Franken-Cooler would probably end up being the direction
Worried about leaks
Worried about failures when running unattended (Kill CPU?)
Case layout may not accommodate reservoir? (Video card right in the middle of the board/case, bays riveted on)
I read tons of reviews of AIO's failing, so those are probably out 'as-is'.
From what I've read, CM 212 EVO is more than enough for the Ryzen processors
Haven't pushed GPU yet, not sure how loud it gets under load
I've seen recent posts here using an electrical box with fish pump for cheap. Are those reliable, can you run two 'tied' loops with redundant pumps? Unnecessary?
I saw another post quoting $400 for a semi-custom setup with just CPU cooling. I really would like to keep it under $200 for CPU/GPU.
I'd like to keep it internal to the case if possible. Car radiator may be out.
-TIA
Zotac GTX 1080 GPU
Pros:
Probably quieter
Fun project
Cons:
Worried about leaks
-TIA
