Hi guys,
I currently watercool my 1080ti using a NZXT Kraken X41. It has good performance but I'd like to take it one step further. I knew about the Thermoelectric effect for a while but didn't really think about utilizing it. I recently saw a video and the idea is that the TEC is a voltage-powered device composed of a small block that has two surfaces, a hot one and a cold one, and the idea is that the temperature difference between the two surfaces is kept constant. So what I want to do is to put the cold side on the GPU die, and the hot one on the waterblock.
Has anyone tried this sort of thing here? Do you have experience with it? Does it work or fail horribly?
Thanks
Thanks
