Here are some links iv kept. Iv also seen the same issues on older Gigabyte boards, I dont hold much hope for getting it fixed.
http://forums.anandtech.com/messageview.aspx?catid=29&threadid=2140149
http://forums.overclockers.co.uk/showthread.php?p=10979525#post10979525
http://www.tomshardware.co.uk/forum/247545-12-e6600-fails-overclock#t1755538
Other boards from Gigabyte.
http://www.tomshardware.com/forum/246134-30-p35c-ds3r-boot-recycle-problem
http://forums.pcper.com/showthread.php?t=439190
They go on and on and on. Its a Gigabyte problem and I think you should send as many links as you have to your retailer and insist that these boards are defective and does not fit the quality and usage it was intended for. When I started seing my very problem with other Gigabyte boards I knew that this one wont get a fix. It would seem that either you have the right combo of components with these boards or it wont work correctly.
