- Nov 1, 2010
- Furfagia
Issue: USB wifi adapter works flawlessly on sig PC as well as an HP laptop, but not on another desktop.
Wifi Adapter: Etekcity High Power 802.11
Sig PC (see sig for other info):
OS: Windows 7 Pro 64 bit
Other desktop PC:
CPU: i5 4670k
RAM: 8 GB G.Skil Ripjaws 1600
GPU: Asus HD 7790
Mobo: ASRock H81M
PSU: Corsair 600 watt
What I Have Tried:
Absolutely bleeping everything. I have had this issue for over a month now. I have re-installed the OS and full up-to-date driver package multiple times. Even after a perfectly fresh install of OS and drivers, the wifi adapter does not work properly. Every USB port has been tested with several other devices, and all work flawlessly (USB hard drive, USB flash drive, USB mouse, USB keyboard). I have literally tried dozens (if not over 100) possible fixes without avail. I cannot recall all of them, so I will add them here as I remember them.
Windows Network Symbol Legend:
No Internet Access (screen with ethernet connector, covered by red X) : A
Internet Access (screen with ethernet connector): B
No Networks Available (empty wifi bars, covered with red X): C
Searching For Networks (empty wifi bars with windows 7's "thinking" symbol [revolving aquamarine circle]): D
Connections Available (full wifi bars with yellow dot): E
Attempting to Connect (full wifi bars with windows 7's "thinking" symbol [revolving aquamarine circle]): F
Connected to Network (full wifi bars): G
Sequence of events as USB Wifi Adapter is registered on "Other desktop PC" for first time:
A > C > D > E
On connect attempt:
E > F > G > B > A > C > A > C > A > C > A > C > A > C > A > C > A.....
Loops continuously between A and C until device is uninstalled form system. If I unplug it, and then plug it back in (or disable it and then enable it), it still keeps looping between A and C. It takes about 7 seconds for a full loop.
I am lost.
Other desktop PC:
CPU: i5 4670k
GPU: Asus HD 7790
Mobo: ASRock H81M
What I Have Tried:
A > C > D > E
On connect attempt:
I am lost.
