My 8800GTX has two Gold Fingers on it
I have two 8800GTX with one SLi Cable
does it matter which one of the two Gold Fingers i use
and now i have a total of 4 DVI connections to chose from
does it matter which one i use
I dont know much about SLI, but I can help with the DVI question. It shouldn't matter which one you use, but usually you'll use the the first card's DVI.
I have used the top card with the DVi closest to the motherboard
I also used the second card with the DVi farthest from the card
I have used the first and the second gold finger
they all work in diffrent way but i am not sure what is the standard of using it
