- Oct 13, 2005
So my OCZ PowerStream 520 died a couple of days ago. Just came home from work and the PC had been turned off and wouldn't come on. I want to get a new PSU and maybe even a UPS to rule out the possibility of brownouts and power surges killing my PCs.
For the PSU, I want something that will work with my sig system, but still have room for the quad core I'm putting in there and maybe even an i7 upgrade in the future. I'm really liking the models from corsair right now, but I'm open to anything. I'm really torn between the TX850 (link) and the HX650 (link). Both are about the same price, but the HX650 is modular, which would be nice if I decided to eventually use it in my future HTPC build. Once again, I'm open to whatever you guys have to suggest, but I don't think I want to spend much more than $150 (unless it's really worth it). EDIT: Thought I'd add the suggestion of the Antec Signature 650 (link)... incredibly low ripple!
I'm totally new to UPSs. I know that there are "true sine wave" UPS and step output ones. I'm an engineer so I think I do understand the physical differences, but I really have no idea if it's worth paying the extra for the true sine ones. I'm primarily going to be powering my computer with this, and I don't really care about the battery run time.... It would be nice to have more than 2 minutes to save documents and shutdown. I'm looking at a 750VA model from APC (link), but I'm not sure if I'll need more than that.
Also, I'll eventually be buying another UPS for my Home Theater (TV, surround, etc) but until then, I wouldn't mind being able to have it on the same UPS as the PC... is that possible, or is there a hard set wattage limit? Keep in mind, I'd only really be using it for the power conditioning and surge protection (don't care about battery life).
Thanks in advance!
Thanks in advance!
