Hey all,
After much debate, I think I've finally decided to go with this cooler. A few questions though ...
1) Is it safe/ok to mix and match fans? It comes with the two stock 140mm's; however wanted to add a third to the bottom.
2) Do you recommend changing the stock fans?
3) Is it recommended to do a push/pull (even though it's only with a 3rd)?
4) Does this truly perform better than say a NZXT Kraken or Corsair that would leverage 4 fans?
5) Am I really going to need to refill the water after 3 years?
6) Do I need to leverage the pmw hub they provide or can I use the one in my case (Phanteks Enthoo Luxe)?
Thanks
Thanks
