- Jan 14, 2011
looks pretty sweet!
edit: added quote
edit: added quote
http://www.sidewindercomputers.com/sw8waypwmsp8.htmlWe generally recommend to use the “CPU_Fan” connector of the motherboard, because most motherboard manufacturers usually allow a greater range of adjustments on this particular connector. PWM capable connectors must necessarily be 4-pin, but not all 4-pin motherboard connectors implement or enable the PWM signal modulation by default. Please carefully consult your motherboard documentation in this respect.
