- Apr 23, 2012
- Los Angeles
Let me tear this apart:
In addition to the fan hub, the NZXT Grid also includes one 200mm Molex to 3-pin power adapter, (Running a lot of 3 pin voltage controlled fans with a 3 pin skinny wire input off a molex? Can you say melt?) one 200mm 3-pin female to female adapter and two 200mm 3-pin male to female extensions. With a matte-black finish, white LED indicator lights and matching fan extension cables, the NZXT Grid ensures the inside of your case looks just as good as the outside. The NZXT Grid will be available soon with an MSRP of $11.99.
It's for 3 fin non PWM. You can adjust the incoming voltage to make all fans at the same voltage input though.
Pretty sure non of the units in testing ever melted.
Additionally, it's a fan hub, not a fan controller. You can use a fan controller to control the hub. Watercooling fans, anyone?
