- Nov 14, 2009
So I decided to switch to a phenom ii x4 955 cpu and in the process get a AM3 motherboard and 2x2GB 1600Mhz DDR3 memory too, but problems arose. To my knowledge I connected everything correctly, but my comp won't boot. The three case fans spin at normal speed, the CPU fan (a coolmaster) spins at really slow speed and my PSU fan does not spin at all.
This was a relatively new PSU that I just purchased 3 or 4 months ago. My old PSU last me over 2 years. So here is my old specs.
My old setup:
AMD Athon X2 4200+ 2.2GHz
3x1 GB 667MHz
1x 160GB, 1x 250GB, 1x 450GB HDDs
550w coolmaster atx 12v
Asus M2N-E motherboard
New setup that doesn't work:
AMD Phenom ii x4 955 3.2GHz
2x2 GB 1600MHz
Gigabyte GA-MA770T-UD3P motherboard
From using online PSU calculator it says I only need 348W PSU to run my system. I have 550W, but my PSU fan does not spin. Can my PSU fan not spin because of a wiring failure or can it only be a dead PSU?
EDIT: after much tinkering I found out that if i change my cpu fan to any other fan slot then the cpu fan spins fast albeit it makes a loud humming noise.
My old setup:
3x1 GB 667MHz
2x2 GB 1600MHz
