Hello,
I am in some dire need of help.
I have my computer that i am trying to play wow on which i can i run a GT420 GPU right now (low end gpu)
Motherboard MSI 7778
Ram: 8 GB
OS: Windows 8
PSU: 600w
I forget the CPU because i am working on 2 computers my wifes and mine. I believe is a AMD A8-5500
I installed the XFX HD7970 GPU. It turns on and runs proper fans spin.
1 6 pin connector and 1 8 pin which is using an adapter from 2 molex to a 8 pin connector.
I can open Unreal (game) which gets around 300-320 FPS if not limited. (NO CRASH)
But i play WoW alot which got around 100fps at Mid-High Graphic Settings (when it turns on for the minute or less)
Sometimes when i open WoW it crashed instantly with either a BSoD(critical_process_died) or Vertical lines.
Sometimes it'll get into game and it will be very laggy/freeze a couple seconds at a time. Then it will crash computer.
This also last night currupted my startup files so i am trying to get the computer back on as it wont start up now (bad_system_config info)
I sent the card back to the guy i bought it from and he sent me his other one which he uses every day and it does the same.
I marked the old one to be sure it wasn't the same card that he sent back.
Someone give me some idea's on why this keeps crashing when trying to play wow it crashed in less then a minute or instantly.
Working on getting pc back running again as well.
Ram: 8 GB
OS: Windows 8
PSU: 600w
