- Feb 18, 2002
System boots only if 4 pin +12V is plugged out, is this a likely mobo or PSU problem?
Only after I plug out the 4 pin +12V does my system power up.
I don't have another PSU with a 4 pin to try to see if this is a PSU or a mobo problem.
I suppose running this without plugging in the 4 pin isn't going to be too bad, but I'd sure like to know if it's the mobo or the Antec TPII-380 PSU...
_____________________
AMD Athlon XP 2500+ AXMH 2500 FQQ4C
IQYHA 0348 SPMW
2 x 512MB Centon PC3200 (Samsung chips) @ 9 4 4 3
[200] FSB x 12 = 2400 MHz @ 1.85 Vcore with memory frequency at 100% [200 FSB] @ 2.90 Vdimm and 1.8 Vdd
Epox 8RDA3+ v2.1, BIOS 07/29/2004
Thermalright SLK-900A with variable speed 80x25mm Thermaltake Smart Fan 2
AIW 9600XT 128MB; Antec SX-835II case ; 380W Antec TruePower2 TPII-380
Five 80x25mm Case Fans
IQYHA 0348 SPMW
