This is my system right now:
1 x Corsair Special Edition White Graphite Series 600T Steel / Plastic ATX Mid Tower Computer Case
1 x ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
1 x EVGA 012-P3-1570-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video ...
1 x COOLER MASTER Silent Pro Gold Series RS800-80GAD3-US 800W ATX 12V v2.3 / EPS 12V v2.92 SLI Ready CrossFire Ready ...
1 x Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics ...
1 x OCZ Agility 3 AGT3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid
State Drive (SSD)
1 x CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML8GX3M2A1600C9B
1 x ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler
1 x Seagate Barracuda ST500DM002 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
My Cpu is overclocked to 4.5ghz at 1.30v i plan to go to 4.8
MY TEMPS right know prime 95 are max 78c and the hottest core running for 30 min
I plan on moving all this into a TJ07 with This Water cooling Hardware
*** HOT *** Koolance CPU-380I Water Block (Intel Processor)
- Nozzles Add Nozzle Pair, G1/4 Compression [13mm, 1/2"] NZL-V13
$84.95
Swiftech MCRES-MICRO™ Rev. 2 Reservoir
$24.95
*** NEW *** PrimoFlex Pro LRT UV Green Tubing -1/2in. ID X 3/4in. OD
$13.50
Scythe KAZE-Q 12 Channel Fan Controller - Silver
$28.95
IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip
$6.99
EK-PSC Fitting 13mm - G1/4 - Black
$13.98
Swiftech MCP655-B Special Edition 12 VDC Pump Without Speed Controller
- Fitting Size Bitspower 1/2" ID 3/4" OD Compression Fittings
- Cable No changes (stock, unsleeved)
- Sleeve Color Black
- Heatshrink Color UV Green
$94.95
*** SPECIAL *** BitFenix Essentials Pro Pack - ATX 24pin, EPS 8pin, 2x PCI-E 6pin Cable Set - Green
$29.95
Arctic Clean - Thermal Material Remover and Surface Purifier - 60ml
$5.95
Tuniq TX-4 Highest Performance Thermal Compound
$9.99
Alphacool NexXxoS UT60 Full Copper 480mm
$119.99
SilverStone (SST-AP121) 120 mm Air Penetrator fan - transparent blue UV blades
- Sleeve Color Neon UV Green
$67.96
GELID Solutions Wing 12 - 120mm UV Green Gamer Fan w/ Nanoflux Bearings - Sleeved
$37.98
*** NEW *** GELID Solutions Wing 9 - 92mm UV Green Gamer Fan w/ Nanoflux Bearings - Sleeved
$33.98
*** NEW *** Evercool HDB-250 2.5inch HDD to 3.5inch Bay Metal Mounting Bracket
$9.90
FilterRight™ 92mm Aluminum Fan Filter - UV Green
$10.98
Sub-Total: $594.95
I Got the Idea From Linus At NCIX
How do you guys think it will look and anything you would change.
I want your opinions. In the future i will be watercooling 1 or 2 high end gtx 680 or 1 690 thats y i am going with a 4x 120 rad
State Drive (SSD)
$84.95
$24.95
$13.50
$28.95
$6.99
$13.98
$94.95
$29.95
$5.95
$9.99
$119.99
$67.96
$37.98
$33.98
$9.90
$10.98
Sub-Total: $594.95
