Hi there I have a Gigabyte motherboard model g41mt-s2pt no choices in the BIOS page system memory multiplier There are two choices bus 1333 and two 4.00a and 4.00c, what is the difference between them Had the bus and the memory modules cause damage
Notable after raising bus memory to 1333 noticed when you open Computer from button energy works Computer for half seconds, then stand for a period also half a second the other then it works does her normal with the flag before raising bus memory the computer is working from the first time when the pressure on the button energy
