Hello.
I ran into a problem - I can't start my new system at all: when Power Switch is pressed _nothing_ is hapenning, even cpu/system fans are not moving for a split second.
And I just was at the shop where I had bought everything - they started it without any problems, might I say they used their own PSU - I'm reusing mine from the previous build and it's functioning well - I just got back to my old mobo+cpu and everything is ok.
Specs:
-Motherboard: Gigabyte Z97P-D3 (in manual it says it requires at least 500W, my PSU has 550 and is certified as gold 80+)
-CPU: Intel i5-4690K
-PSU: Seasonic SSP-550RT
-RAM: 2x8Gb Kingston 1600Mhz Red Fury
I guess other specs are irrelevant (two fans, 1 ssd and hdd, video). I even tried disconnecting video card power - didn't help.
I also tried reseating ATX and ATX 12V (there are 2x12V connectors/cables on mobo and PSU), flipped around the power switch pin connector - even tried touching pins with a metal screwdriver - the system doesn't respond at all. I'm baffled, does anyone have a suggestion? Thank you.
Specs:
