I import the CPU database of this forum of about 800 TBred 1700+ and 2100+ CPU listed below, into a spreadsheet.
These are some findings from the data for further discussioins:
1. The TBred B 1.6V 2100+ still the winner, max CPU frequency averaged about 110 MHz over the TBred B 1.5V 1700+ DLT3C.
2. The TBred B 1.5V 1700+ DLT3C, max CPU frequency about 160 Mhz over the TBred B 1.6V 1700+ DUT3C.
It shows also how well the 1.5V 1700+ DLT3C overclocks compared to the 1.6V DUT3C, and the 1.6V 2100+, all are Tbred B.
CPU data used:
1. 335 TBred B 1700+ (which include DLT3C and DUT3C)
2. 55 Tbred B 1700+ DLT3C only (This is from the 1700+ DLT3C poll put up by {PMS}fishy)
3. 156 Tbred A 1700+ (this is just for counter check the numbers)
4. 237 Tbred B 2100+
These are the results:
TBred B 2100+
Mean CPU frequency = 2338 MHz
Std Dev = 174 MHz
TBred B 1700+ DLT3C only
Mean CPU frequency = 2226 MHz
Std Dev = 236 MHz
TBred B 1700+ (all DLT3C + DUT3C)
Mean CPU frequency = 2147 MHz
Std Dev = 195 MHz
TBred A 1700+
Mean CPU frequency = 1877 MHz
Std Dev = 167 MHz
Remarks:
1. In the poll for the 1.5V 1700 DLT3C, the sample of 55 is not as large as the 2100+ and 1700+ (DLT3C+DUT3C), and so may be skewed a bit. Also, there may be some errors of DUT3C being entered there and so lowered its oc frequency a bit. So I think the difference between the 1.5V 1700+ and 2100+ should be a little bit smaller.
2. Both air cool and liquid cool CPU data are used.
3. It remains to be seen whether the 1.5 V DLT3C can be clocked higher than 2.5 GHz if more setup are being worked on with liquid cooling (since the DLT3C is still new, no many aggressive oc yet). That will help the DLT3C to bring the oc frequency average higher. I heard there are DLT3C oc to 3GHz (not in the poll data used).
CPU data used:
TBred B 2100+
Std Dev = 174 MHz
Std Dev = 236 MHz
Std Dev = 195 MHz
TBred A 1700+
Std Dev = 167 MHz
Remarks:
