- Oct 30, 2003
- Woodridge,IL
I just picked up a Swiftech MCW462-UHT,a MCW50-T and a Mean Well 12V 25A PSU. I have a 12"x12" sheet of viton to insulate the backside of the MB and my 9700. I will fill the holes in the CPU socket with dielectric grease and spray the front and backsides of the MB and 9700 with Konform SR. I have the closed cell foam parts for both blocks. I will run the CPU Block (226W TEC0 from the Mean Well and the VPU Block (80W TEC) from my PSU. Some questions:
1) Could I run both TECS from the Meanwell PSU? It's rated at 25A and the Swiftech Info for the CPU Block shows 24A max draw. The GPU Block is supposed to draw 7.5A max. I think I am OK with the above plan, I have a good PSU, but with both a 9700 Pro, this TEC and my OC I do wonder. If I could run both of them from the Mean Well I would probably do do. My calculations show that the 226W CPU TEC should draw about 17.5A @ 11V and the 80W GPU TEC should draw abour 5.5A @ 11V. I also show that I would get optimal results @ 11V (best combination of hot side temp - Hot/cold side temp difference). In a related note, if anyone knows the maximum 12V current draw of a Radeon 9700 Pro I would find that information to be most useful.
2) Should I get another relay kit for the Mean Well like the Swiftech one I use for my Eheim Pump? How long does it take for the TECs to reach min temp? Do I need to turn them on first like with A Promethia or do the cool almost instantly> I will be going for the maximum OC I can.
3) Rite now I have an Eheim 1250 fed from an attached Innovatec Tank-O-Matic-Large resevoir feeding a MCW5000A cooled by the Swiftech 80mm rad with dual fans and an external BIX Pro with 2x120mm Panaflo L1As. Is this enough? Also I have an extra Eheim 1250 and an unused bayres. Should I use these to provide a completely seperate loop for the GPU? Ie.. 1250 + res + BIX for the CPU and 1250 + res + 80mm rad for the GPU? and which res woulod be better for which loop? I am a little uncertain about installing the bayres anyway as there have been some reports of leaking which has caused me to leave mine idle.
Frankly I'd just as soon sell the extra pump/res and the huge Zalman HS that came with my 9700 if I could.
Any other pointers/suggestions would be greatly appreciated.
