I bought a group of 5 commercial water chillers a few years back. This was an eBay purchase. Last night, just for giggles, I decided to check one of them out.
Description: (sorry no pics) They have a roughly half-gallon sized plastic tank. There is an aluminum heat sink mounted on the tank's side. The heat sink has a 120mm fan exhausting away from the heatsink. The fan is fairly quiet - maybe 30 db. A sticker on the base of the unit states that it draws 65 watts +or- 5% at 13 volts. Then there is a figure showing operating temperatures of 10-38 degrees C. The tank has input (top) and ouput (bottom) nipples that takes 1/2 or 3/8 inch ID hose. Then there is a hole of about 1/2 ID on top. I assume this is for filling the tank. Finally, there is what appears to be a thermister mounted inside the tank. The thermister has a small molded two-pin socket with red and black wires. I haven't checked the ohms rating on that.
These are not fully complete units. They seem to have been salvaged from units taken out of service. The worst news is that there is NO controller. Thus, they run at full power as long as the power supply is running.
I decided to try one out last night. I plugged the input/output holes. Filled the tank with water. Connected the fan and the TEC wires (both are black and red) to an automotive 13 amp 12 volt power supply. It puts out around 13.1 volts.
I inserted the probe from a meat thermometer into the fill-hole before starting. The temp of the water showed as 71.2 degrees F. Then I ran the unit. There was no insualation - the unit was just propped up on my tool bench. The thermister was not used.
Results:
after...
30 minutes - the tank water temp was 62 degrees F.
60 minutes - water tank temps were 53 degrees F.
90 minutes - water tank temps were 46.1 degrees F.
120 minutes - water in the tank had reached 44.1 degrees F.
I terminated the experiment because it was late. The fan seemed to cool the heatsink pretty well. The heatsink never got really hot. And the water temps in the tank was dropped significantly (roughly 27 degrees F), though the cooling pace wasn't what I'd call robust. Obviously a 65 watt TEC just doesn't have a whole lot of cooling capability.
I water cool one overclocked Intel Core I5 2500K. My water cooling system is an external home-brew setup. It's currently being revamped. I was waiting for some parts for it when I decided to perform the above test.
Part of me wanted to use one of these chillers to cycle on to give me water cooling reservoir a 'shot in the arm' when the system is under stress.
My guess is that the cooling offered my these chillers is too small to be useful. I got all five for under $20 - with the shipping. So I don't feel cheated. I'm sure the guy who sold them was disappointed that he didn't get more for them. I never got around to trying them out until now. I just wish I could think of some way to make use of them - besides for cooling refreshments.
Anyone have any practical ideas? (I'm talking for my water cooling system.)
Bach On
Results:
after...
Bach On
