Hi everyone,
I am currently building my first WC system and was wondering, as far as a solution for monitoring my WC CPU temperature via fan controller. Do you think useing....Bitspower G 1/4" Temperature Sensor Stop Fitting ,
http://www.frozencpu.com/products/1...e_Black_BP-MBWP-CT.html?id=UByIRu2f&mv_pc=149
In one of the non-used ports in a..Swiftech apogee HD 4-port would work??
http://www.frozencpu.com/products/1...-BK.html?tl=g30c323s835&id=UByIRu2f&mv_pc=628
If the sensor doesn't fit, Then I was thinking of creating a "T" in the line right after the outflow from the CPU water block and sticking the sensor in that??
I have the wire Temp sensors that came with the Fan controller, but I'm scared that the sensor itself would melt, or melt what ever I could fine to keep it attached to the cpu, if placed on the CPU directly...or interfear with cooling as other posts have said.
Suggestions??
Thanks, Chris.
Suggestions??
Thanks, Chris.
