- Mar 13, 2011
- Chaparral, New Mexico
Well I moved my rig over to a new case, idle was around 38ish, p95 would sent me to the 80s. I knew that was too high. Pulled off the water block, and I could see I used way too much tim.
Reapplied using the x method using Prolimatech PK1 but with less this time. Max temp across 3 cores is 74c, however the first core max is 67. Seems I may need to reseat the block again.
I am currently at 4.8ghz @ 1.456 volts. I am not yet sure of the ambient, but it is pretty high, computer sits in a 5'x8' closet. Off hand, do these temps look a bit high, or are they ok given the location and voltage?
