Yamiyanazz said:I would suggest CheckeMON. It will run all sorts of tests for absolutely free. Never have to register and it's very easy to figure out. It'll test all your colors, banding, and all that good stuff.
For ghosting, I learned this trick on the forums. Open a game of MS Solitare and drag a card around on the green background. It'll give you a fair idea.
stereo555 said:Hey Yamiyanazz ....I just went to the site you listed and my Avast virus program kicked in , telling me NOT to load the page as it contains a virus !!!
Now , not all virus programs are perfect , but Ive had XINT results from Avast ; so I'd imagine what Avast is telling me has a very good possibility of being true . Seems it may have been the pop-up too that was blocked .
Anyway , just a heads up to anyone linking to the above . Can anyone else confirm ?
Yamiyanazz said:Interesting find, stereo555. I took this into consideration after your pointing it out and decided to upload the file to http://virusscan.jotti.org to check for any virus among several virus programs. It returned negative with no viruses found, even when scanned with Avast.
However, it did return as "MIGHT BE INFECTED/MALWARE (Sandbox emulation took a long time and/or runtime packers were found, this is suspicious. Normally programs aren't packed and don't force the sandbox into lengthy emulation. Do realize no scanner issued any warning, the file can very well be harmless. Caution is advised, however.)"
This is suspicious, plus your scan that recognises it. Being inconclusive, I would say that the program should be used at your own risk. Thank you for pointing this out, stereo555.
