- May 4, 2012
Hi fellow OCers, as I'm new here I thought what better way to introduce myself than making a thread and asking you fine folk a question or two
I'm in the process of my first mATX build and consider myself fairly adept at researching and selecting suitable and compatible components but I have to admit, choosing the right cooler for an mATX mobo/case is an arduous task.
At first I started looking at what the best coolers were, all the while I continually found the Noctua's being recommended but I just personally feel they are overpriced as you can get similar performance for considerably less. The other option that came up was CLCs but to summarise I looked into them and realised they weren't for me at this moment in time/
Based on price/performance I began to be interested in mounting the mammoth Silver Arrow on my tiny board but after some extensive reading I decided it was either impossible (depending on the motherboard you have and the clearance between socket and GPU slot) and where it was possible it appeared to be fairly impractical for getting around your mATX case. Perhaps foolishly, I though the Thermalright HR-02 Macho might have been a slightly better option but after realising the clearance issues were more related to the TY-140 fans used on many of their coolers (which is actually 151mm wide in one direction) I started to look a little further down the food chain for something with a bit more breathing room.
Whilst looking into the HR-02 I came across another issue with certain TR coolers coupled with certain ASUS/ASRock motherboards, which required a special mounting plate. After trying to get to the bottom of this I eventually discovered that it came down to some boards having VRM heatsinks that encroached upon the socket exclusion zone - having examined my motherboard I am fairly confident I shouldn't be effected.
So sticking with TR, I am thinking a sensible option might be the TRUE Spirit 120mm. I've seen a couple of reviews were it seems to be fairly on par with the TRUE Spirit 140 and HR-02 and what's nice is that I can get this cooler for less than the oft-touted Hyper 212 Evo. So I'm coming here to see what you guys thing of this cooler, is it a good choice? About the only thing I can't discern is whether or not the stock fan is any good. Some reviews say it's quiet, one puts it quieter than the TY-140 but based on the specs and the general comments I've collected the fan is probably quiet noisy.
I should state at this point that one of the primary factors for this build is for it to be cool yet as quiet as possible - that's partially why I looked at the TR coolers with the TY-140 as I was led to believe these fans were pretty quiet.
So, should I be looking for a different fan to pair with the TRUE Spirit 120? Since it's reasonably priced my budget would allow getting an replacement fan. What 4-pin PWM fans would you recommend as a replacement that would offer similar or better performance to the stock fan but do so with very quiet operation?
Any comments, thoughts, suggestions are greatly welcomed.
