- Oct 14, 2007
@Rabid, you will be going to the same school I am at , small world. PM sent to you
@Mike, there are a lot of threads about 101 Dry Ice in the Extreme Cooling section. The guys here are more than capable of helping you get started. As far as what has changed with DI, nothing. Its still set the pot, make sure the insulation is good, and bench for crazy amount of hours.
A quick cheat sheet:
1) Start with something you won't miss too terribly if it goes BOOM. It probably won't, but still.
2) Make sure all the heatsinks are making good contact, ask Chance if you want to know what happens if they aren't. I mention this because you can dislodge them trying to stuff eraser under them.
2.a) There is no need whatsoever for you to use kneaded eraser on AM3 socket motherboards. You can get the same level of insulation/protection by using FrostKing... Same protection - Less hassle = FTW
3) If things suddenly go wonky during testing and won't run at settings you know for a fact used to work, shut down immediately. Something got wet.
4) ice does not conduct for beans, it's safe.
5) Water is death to shiny things, bare metal contacts, pins, etc.
I certainly can't say that, never used it
The local AirGas will not have anything until next week
THE EVENT IS CANCELLED!!
I just got a call from the AirGas in Rolla. My order for the 20L cannot be filled because a Medical facility needs it.
What the hell does a medical facility actually use Ln2 for?
