Hello to everyone at OC.
Ok. A good friend of mine has come to me and said, "I want the best PC you can build me". He given me a budget of around 5-6 Grand (£5-6000). I have a small amount of knowledge and have put together to as what I think will be a stunning system.
So far i have:
BFG 7900GTX 512MB DDR3
PCI-E
(Times Two in SLI)
Thermaltake VA8000BWS Armour Super Tower
Black
Western Digital WD740GD 74GB "Raptor" 10,000RPM
Times FOUR in RAID-0
Asus A8N32-SLI Deluxe Socket 939 Nvidia NF4 ATX
WaterChill Xtreme CPU/VGA/Chipset Cooling Kit
- WaterChill Antarctica CPU Cooler (Socket /939/
- WaterChill Chipset Cooler
- Triple Black Ice Pro 120mm radiator
- 6x 120mm low noise Adda fan
- Software based control panel
Athlon 64 FX-60 Socket 939 Dual Core 2.6GHz 2x1MB Cache
OCZ (OCZ4002048ELDCPE-K) 2 x 1 GB EL DDR PC-3200 Dual Channel Platinum
Hiper 580W Type-R Modular PSU
Belkin 650VA Superior Series Emergency Battery Backup F6H650UKUNV (UP-012-BE)
Microsoft Optical Desktop Elite For Bluetooth
Creative SoundBlaster X-Fi Elite Pro
LG GSA-4167BAL 16x DVD±RW Dual Layer Internal IDE (Times two)
Creative Labs Gigaworks S750 7.1-THX
SATA/SERIAL ATA PCI RAID CARD 4 CHANNELS /6 PORTS (4+2)
Belkin Hi-Speed USB 2.0 5-Port PCI Card
Hauppauge WinTV-PVR500 Dual TV tuner Media center Upgrade kit
Maxtor 6L300S0 DiamondMax 10 300GB 7200RPM SATA/150 16MB Cache
(Times two also in RAID-0)
Western Digital Serial ATA Secure Connect.
I haven't made my mind up on a Screen to go with it yet. I have a £500 pound budget on that. Can anyone see any problems i will come into runnning this for example one part is bottlenecking another or components has compatibility issues with another. Could you lot suggest what a good monitor for the price would be? Im looking for around a 20" plus, 19" minimun and bigger if poss but has to live up to the graphics cards etc.
So far i have:
PCI-E
(Times Two in SLI)
Black
