I have it at 2.75V. Timings are now 2.5-3-2-10 with Aggressive mode enabled on 1T. This memory is having trouble with cas latency of 2 and Ras-to-cas of 2. It's stable enough to benchmark, but memtest errors out, so it isn't worth it. However, Sandra wasn't reporting a significant difference between 2.5-2-2-10 and 2.5-3-2-10 anyway... about 50MB/s.
Rated timings are 2-3-2-8, which is impressive for PC4000. I suspect that it's either the motherboard or more likely the CPU that doesn't want to hold that. Maybe with DDR Booster...
Odie
UPDATE (2 hours later): Well, 9x250 at 1:1, 1T is no problem for this memory/CPU. Bandwidth went up about 150MB/s, while CPU arithmatic score dropped by 500 flops. I think I'm going to stick with 10x240 for now and let it settle in for overall performance. I was able to boot at 10x250, but Windows started to freeze. I'm sure it is the CPU, but I'm going to mess with some settings before I max the VCore at 1.8V. Although, at 1.75V, my temps never hit 50C. Is it worth bothering trying with the memory set to 2T?
