- Nov 2, 2005
- Dawsonville, GA
From Thermalright's website:
It seems that most people here believe that lapping improves temps, especially load temps. For instance, lot of posters in this thread (http://www.ocforums.com/showthread.php?t=517514&highlight=lapping) claim to benefit from lapping to the tune of around 1C-2C idle and 3-5C load. The problem is, those are the exact same results one should observe after the AS5 curing process has completed.
From the Arctic Silver website:
So my question is, how do you guys know you're not just seeing the AS5 kick in, as opposed to getting better temps from lapping?
Question 5: The bottom of the Ultra-120 eXtreme isn’t very shiny. Would I get better results if I lapped it?
Answer: A shiny surface does not necessarily mean a flat surface. Lapping only eliminates some of the larger gaps between the grains. We have demanding criteria for high quality especially when it comes to our heatsink base. The Thermalright heatsink you purchased does have a relatively flat surface therefore we do not recommend risking damage to your heatsink or your CPU DIE by lapping because results may not always be positive.
On systems measuring actual internal core temperatures via the CPU's internal diode, the measured temperature will often drop 2C to 5C over this "break-in" period.
