ThermalTake View 91
petteyg359
Likes Popcorn
I recently built a new Ryzen system in this case. Just wanted to say it's vastly superior in build quality to the Corsair 900D I used for my last system. Everything including the magnetic dust filters just fits, none of the snaps are finicky. Could use less bling so I replaced all the Really Garishly Blingy fans with Noctuas. No experience with their other cases, but if you need a full tower, I'd definitely go with TT over Corsair.
That's a beast of a case! How is intake air from the front though? Looks like limited sized gaps for air.
Oh and...
:pics:
There's about a 1/8" gap between the front glass and the side glass. I didn't capture it well at this picture angle, but plenty of space for air intake. The rolling base I made from stuff from the local McCoy's. There are another three AF-14s in the top not visible from this angle. All the fans but the CPU are running off of a hub behind the mobo. CPU fans are on the back of the cooler so I could get to the RAM because I had a bad set initially. On that note, Crucial RMAs are very quick and easy. ttview91.jpg
